Trouble with ARP Tables over SNMP
Hi There,
We are currently using software to map out our clients networks and look for issues. Currently we are running into an issue, and support says that ARP tables are not available over SNMP with the Zyxel USG models.
I am assuming this is a long shot, but wanted to make sure there wasn't something I might be missing in the possibility of enabling that or finding a workaround.
Thanks for any help!
Hey @Alfonso!
Thanks for the quick response. Just running a temporary test from a Windows Machine with snmpwalk installed (which is questionable at best) I am getting a "No Such Object Available on this agent at this OID" Error. This appears to be inline with what our software provider is saying
Thanks0 -
Iif it is not implemented, it should be.
Maybe this thread should be moved to Idea forum.1 -
Yeah this is a real shame, I will post in the idea forum.
Thanks for your help, If anyone else has further info please let me know.0 -
I can also support this feature request. The possibility to read by SNMP the switch forwarding db and the LLDP neighbours0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
