Importing certificates compatibility openSSL vs certutil
PeterUK
PeterUK Posts: 3,985  Guru Member
edited December 2023 in Security
Old models of USG like Zywall 110 or USG 60 don't work with opeSSL command
openssl pkcs12 -export -out cert.pfx -inkey key.pem -in cert.pem
errno: -17011
errmsg: PKI certificate type is not supported
Yet on VPN300 and FLEX 200 it will happily accept it
and using
certutil –MergePFX cert.cer cert.pfx
works on Zywall 110 or USG 60 and VPN300 or FLEX 200
I'm guessing a old copy of openSSL will work?
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,344  Zyxel Employee
    Hello @PeterUK
    Thank you for your inquiry. Could you specify this question "I'm guessing a old copy of OpenSSL will work?" for us in more detail? Thank you.
    Maybe there is another openssl for windows but I used this
    https://slproweb.com/products/Win32OpenSSL.html
    I tried older versions to see if newer version cause old USG model to not work but it still failed
  • Zyxel_Jeff
    OK, noted. Thank you for your update.
    edited February 2024
    So after some testing for anyone the openSSL for windows will not work for the USG 60 or Zywall 110 and other model but will for newer models like FLEX200
    I tried the openSSL in linux mint and had the same problem for USG 60 or Zywall 110 until you add the
    -legacy
    openssl pkcs12 -export -out /home/dns/ddns.pfx -inkey /home/dns/ddns.key -in /home/dns/ddns.crt -legacy
