USG20w-VPN WiFi Issues (No Internet when Connected / Guest Only)
NSIT
NSIT Posts: 20 image  Freshman Member
First Comment Sixth Anniversary
edited April 2021 in Security
Hi Guys,
Suddenly the guest wifi of my customer stopped working, his son hit the reset button thus we had to restore config..Upon restore i noticed the guest WiFi does not grant internet access, wifi connects but says NO Internet..
I disabled Guest and enabled the main SSID which works no problem..I was wondering if there's a firmware bug and also if there's a way to block traffic to the LAN with the main SSID as a temp solution.
As always your help is much appreciated
  • Zyxel_Emily
    Hi @NSIT,
    Can you share the configuration file with us via private message to check the symptom?
