[NEBULA] When will NAP disassociate clients?
Triceratops
Triceratops Posts: 8
edited April 2021 in Nebula
I'm wondering that what's the criteria of Nebula AP to disassociate the clients? Is there a RSSI threshold? If yes, can we manage it?
  • Zyxel_Charming
    Zyxel_Charming Posts: 25
    edited May 2017
    Hi Triceratops,
    The mechanism of signal threshold to do the roaming is now default disabled on NAP.
    So there's no exact signal strength threshold value to disassociate stations.
    NAP won't disconnect client even when the signal is poor.
    If the customer see the disconnecting behavior, it'll be the stations' action to leave/roam the NAP.
    However, here's a good news that the RSSI threshold will be addressed in our further plan.
    As the feature applied, you can control the roaming threshold by changing the value of RSSI criteria.
  • Triceratops
    Hi Charming,
    Thanks for your reply and look forward to the enhancement.
Nebula Tips & Tricks
