Migrate flex 200 to Flex 200H
I got the new Flex200HP now if i import conf file from old Flex200 (NO HP version) i get a error message. Can someone tell me how to do this.
with the old version i did not use zyxel nebula.
The goal hopefully is to make the H series the same as last models at some point (stuff is missing) I think the main reason is performance.
Its a whole new config format you have to start over
that was not the answer i was hoping for😅 no other workarround?
Hi @Mathije ,
Greeting Forum,
Both devices are developed by different platform, so we don't have convert tool currently.
Please feel free to contact us if any concerns.
Thank you
Can the Flex 200h be managed locally like the Flex 200?
Does the Flex 200h do the same things as the Flex 200?
Can you explain the primary primary differences between the two? It looks like performance
is the big part.
Yes the Flex200h can be managed locally
If the flex200 does the same i cant give a answer now, Because of manual setup what i dindt expect it takes a little longer.
i have did purchase this device because of the 2.5 gigabit network for same reason as above i cant give any answers if it works better. I will give a new post later.
We have been using the Flex 200 for our data center customers.
Each customer gets their own Flex 200 with our service. This way they can manage l2tp, ipsec, SSH on their own. We handhold where required. But vs a place like AWS, adding and modifying these features can become confusing for users.
While in the Racks themselves we have 10g backbone switches, so performance within the rack is killer.
So far, we are replacing all our old Zyxel USG 1000 devices, and are very happy with the Flex products.
Cheers,
Bret
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
