USG110 - permanent CPU usage of about 30%
Hi @USG_User,
Can you share the configuration file with us via private message?
We'd like to check if the same symptom can be reproduced.
Hi Emily,Just updated the USG to v4.32 (AAPH.0) and the AP from V5.00 Patch 4 to Patch 5. Now the CPU utilization looks great
We are happy so far, but will check all the other functionality during next days.One question: why IPSec VPN takes 2.8% CPU since IPSec VPN is disabled with us? Only SSLVPN is activated.Many thanks and best regardsJoerg
Hi @USG_User,It is a normal behavior that there is CPU usage for IPSec VPN even if no IPSec VPN is configured or enabled because the daemon of IPSec VPN is up and keeps interoperating with the system.That's why the daemon occupies some CPU usage.0
- 588 USG FLEX H Series
- 477 News and Release
