VPN solution with USG20-VPN and Fritzbox
2»
  • Thanks a lot @PeterUK , that works perfect. I also added the Key groups DH14 and DH19 groups in Phase 1 to enable VPN from iOS. With DH2 it did not work for me.
    As I now have a more secure feeling I would like to ask if anybody of you worries about the connections attempts in the monitor logs from other countries? Since the VPN gateway is enabled I see connection attempts in the logs like this which is definetly not mine. Is that anything I have to worry about?
    PeterUK Posts: 4,362 image  Guru Member
    edited January 2024
    Exposing any port is a risk but if your patched it fine.
    If you want to up the security you can have your clients run DDNS and on your side allow from source them FQDN to Zywall works really well.
  • Hi @Zyxel_James ,
    thanks for your answer and the instruction link. I checked it and it works to get the configuration from the server, but no connection can be established. Here is what the IKE logs says:
    6
    2024-01-04 10:38:04
    info
    IKE
    IKE SA [VPN_Home] is disconnected
    192.168.10.153:500
     80.187.120.128:500
    IKE_LOG
    7
    2024-01-04 10:38:04
    info
    IKE
    The cookie pair is : 0x8fa5b15cd3cbf7bd / 0x187b653fb168338d
    192.168.10.153:500
     80.187.120.128:500
    IKE_LOG
    16
    2024-01-04 10:37:46
    info
    IKE
    192.168.10.153:500
     80.187.120.128:500
    IKE_LOG
    17
    2024-01-04 10:37:46
    info
    IKE
    The cookie pair is : 0xdb227cc9faba3f7d / 0x2bd4af28c484e1fc
    192.168.10.153:500
     80.187.120.128:500
    IKE_LOG
    19
    2024-01-04 10:37:32
    info
    IKE
    IPsec SA negotiation failed
    192.168.10.153:500
     80.187.120.128:500
    IKE_LOG
    20
    2024-01-04 10:37:32
    info
    IKE
    [AUTH] Recv:[IDi][AUTH][SA][TSi][TSr][NOTIFY][NOTIFY]
     80.187.120.128:4500
    192.168.10.153:4500
    IKE_LOG
    21
    2024-01-04 10:37:32
    info
    IKE
    The cookie pair is : 0x187b653fb168338d / 0x8fa5b15cd3cbf7bd
     80.187.120.128:4500
    192.168.10.153:4500
    IKE_LOG
    22
    2024-01-04 10:37:32
    info
    IKE
    [INIT] Send:[SAr1][KE][NONCE][NOTIFY][NOTIFY][NOTIFY][CERTREQ][VID][VID][VID][VID][VID][VID]
    192.168.10.153:500
     80.187.120.128:500
    IKE_LOG
    23
    2024-01-04 10:37:32
    info
    IKE
    The cookie pair is : 0x8fa5b15cd3cbf7bd / 0x187b653fb168338d [count=2]
    192.168.10.153:500
     80.187.120.128:500
    IKE_LOG
    24
    2024-01-04 10:37:32
    info
    IKE
    Recv IKE sa: SA([0] protocol = IKE (1), spi_len = 8, spi = 0x8fa5b15c d3cbf7bd, AES CBC key len = 256, HMAC-SHA256 PRF, HMAC-SHA256-128, 521 bit ECP, 384 bit ECP, 256 bit ECP, 8192 bit MODP, 6144 bit MODP, 4096 bit MODP, 3072 bit MODP, 2048 bit MODP, 1536
     80.187.120.128:500
    192.168.10.153:500
    IKE_LOG
    25
    2024-01-04 10:37:32
    info
    IKE
    The cookie pair is : 0x187b653fb168338d / 0x8fa5b15cd3cbf7bd [count=2]
     80.187.120.128:500
    192.168.10.153:500
    IKE_LOG
    26
    2024-01-04 10:37:32
    info
    IKE
    192.168.10.153:500
     80.187.120.128:500
    IKE_LOG
    27
    2024-01-04 10:37:32
    info
    IKE
    The cookie pair is : 0x23ab84b2fe0eacf7 / 0xdaf4ccf9d50fc3f1
    192.168.10.153:500
     80.187.120.128:500
    IKE_LOG
    28
    2024-01-04 10:37:32
    info
    IKE
    Recv IKE sa: SA([0] protocol = IKE (1), AES CBC key len = 256, HMAC-SHA256 PRF, HMAC-SHA256-128, 521 bit ECP, 384 bit ECP, 256 bit ECP, 8192 bit MODP, 6144 bit MODP, 4096 bit MODP, 3072 bit MODP, 2048 bit MODP, 1536 bit MODP, 1024 bit MODP, 768 bit MODP;
     80.187.120.128:500
    192.168.10.153:500
    IKE_LOG
    29
    2024-01-04 10:37:32
    info
    IKE
    [INIT] Recv: [SA][NONCE][NOTIFY][NOTIFY][KE][VID] [count=2]
     80.187.120.128:500
    192.168.10.153:500
    IKE_LOG
    30
    2024-01-04 10:37:32
    info
    IKE
    Receiving IKEv2 request [count=2]
     80.187.120.128:500
    192.168.10.153:500
    IKE_LOG
    31
    2024-01-04 10:37:32
    info
    IKE
    The cookie pair is : 0xdaf4ccf9d50fc3f1 / 0x23ab84b2fe0eacf7 [count=2]
     80.187.120.128:500
    192.168.10.153:500
    IKE_LOG
    33
    2024-01-04 10:37:14
    info
    IKE
    192.168.10.153:500
     80.187.120.128:500
    IKE_LOG
    34
    2024-01-04 10:37:14
    info
    IKE
     80.187.120.128:4500
    192.168.10.153:4500
    IKE_LOG
    35
    2024-01-04 10:37:14
    info
    IKE
    The cookie pair is : 0x2bd4af28c484e1fc / 0xdb227cc9faba3f7d
     80.187.120.128:4500
    192.168.10.153:4500
    IKE_LOG
    36
    2024-01-04 10:37:14
    info
    IKE
    192.168.10.153:500
     80.187.120.128:500
    IKE_LOG
    37
    2024-01-04 10:37:14
    info
    IKE
    The cookie pair is : 0xdb227cc9faba3f7d / 0x2bd4af28c484e1fc [count=2]
    192.168.10.153:500
     80.187.120.128:500
    IKE_LOG
    38
    2024-01-04 10:37:13
    info
    IKE
    Recv IKE sa: SA([0] protocol = IKE (1), spi_len = 8, spi = 0xdb227cc9 faba3f7d, AES CBC key len = 256, HMAC-SHA256 PRF, HMAC-SHA256-128, 521 bit ECP, 384 bit ECP, 256 bit ECP, 8192 bit MODP, 6144 bit MODP, 4096 bit MODP, 3072 bit MODP, 2048 bit MODP, 1536
     80.187.120.128:500
    192.168.10.153:500
    IKE_LOG
    39
    2024-01-04 10:37:13
    info
    IKE
    The cookie pair is : 0x2bd4af28c484e1fc / 0xdb227cc9faba3f7d [count=2]
     80.187.120.128:500
    192.168.10.153:500
    IKE_LOG
    40
    2024-01-04 10:37:13
    info
    IKE
    192.168.10.153:500
     80.187.120.128:500
    IKE_LOG
    41
    2024-01-04 10:37:13
    info
    IKE
    The cookie pair is : 0x2c1cf186d4a913f5 / 0x7223966460b10d98
    192.168.10.153:500
     80.187.120.128:500
    IKE_LOG
    42
    2024-01-04 10:37:13
    info
    IKE
     80.187.120.128:500
    192.168.10.153:500
    IKE_LOG
    43
    2024-01-04 10:37:13
    info
    IKE
     80.187.120.128:500
    192.168.10.153:500
    IKE_LOG
    44
    2024-01-04 10:37:13
    info
    IKE
     80.187.120.128:500
    192.168.10.153:500
    IKE_LOG
    45
    2024-01-04 10:37:13
    info
    IKE
    The cookie pair is : 0x7223966460b10d98 / 0x2c1cf186d4a913f5 [count=2]
     80.187.120.128:500
    192.168.10.153:500
  • 6
    2024-01-04 10:38:04
    info
    IKE
    192.168.10.153:500
     80.187.120.128:500
    IKE_LOG
  • mm_bret
    mm_bret Posts: 67 image  Ally Member
    PeterUK game some good insider stuff for modifying the encryption on the Windows client.
    Here's some steps for a Windows 10 vpn client.
    L2TP-Windows 10
    1. Click Windows Start Icon
    2. Click Settings Gear on left of popup window
    3. Click Network and Internet
    4. Click VPN on left panel
    5. Click [+] Add a VPN Connection
    6. VPN Provider
      -Select Built in (from list)
      -Connection Name enter: name your l2tp connection-Server Name or Address enter: (ip of USG router)
      -VPN Type: L2TP/IPSEC with preshared key
      (When selected Preshared key text box will appear)
      -Preshared key enter: (enter the pre-shared key you created on your usg router l2tp gateway)-Type of sign-in info: User name and password
      -User name enter: (name of user created on the USG /Object User)
      -Password enter: (password of user created on the USG /Object User)
      Save Connection
    Sounds like you have this solved, just adding to the pot.
