wan failover at flex200HP
Mathije
Mathije Posts: 5
edited January 2024 in Security
I can't find instructions how to setup wan failover for the flex200 HP
only option in trunk is weighted round robin?
can someone help me?
Scherm­afbeelding 2024-01-06 om 23.43.49.png Scherm­afbeelding 2024-01-06 om 23.44.04.png
    PeterUK Posts: 4,688 image  Guru Member
    edited January 2024 Answer ✓
    wan failover currently can't be done by routeing and should be possible to do ARP failover in trunking.
    Make a new User-Defined Trunk add in WAN set one the active the other to Passive
    You then may need to make a routing rule for next hop trunk you have made
    their is also interface pinging check that you can enable
    Edit: testing here shows it working as said above you you need interface pinging check on active WAN when it fails it changes to the Passive WAN then when active WAN is up you switch back for new connections
  • Mathije
    thnx i am not a it pro so i try to set this. (i dont understand it yet but try to work it out)
