which Zyxel firewall can i used for hotel apartment?
Hi @usman,
In order recommend you a firewall to match requirement for hotel apartments, we also need to know if you need Hotspot and AP controller features.
If you need AP controller feature only, you can consider ATP800 or USG FLEX 700.
If both Hotspot and AP controller features are required, we suggest you use USG FLEX 700. (Note: ATP800 doesn't support Hotspot feeature.)0
Hi @usman,
If both Hotspot and AP controller features are required, we suggest you use USG FLEX 700. (Note: ATP800 doesn't support Hotspot feeature.)0 -
USG FLEX 700 with hotspot licence and UTM security; in same scenario ,and don t forget to handle managed switch layer 3 and 2
- 441 Beta Program
- 210 Nebula Ideas
- 538 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
