Why my iPhone 12 is connecting only to the Guest setting?
Grullooo
I have recently configured a Zyxel VMG3925-B10C to my network and from one day to the other my iPhone won't connect to the Internet any longer but will connect to the guest settings?
Please help! 🙏
Thanks in advance!
It looks like you enabled the guest settings on the VMG3925-B10C.
You can forget the guest settings on your phone and disabling the guest settings on the VMG3925-B10C.
Thanks but if I do that I loose connectivity on my iPhone 12. I had to enable the guest setting on the router as that's the only way I can connect with that particular device.
Any other suggestions please?
same problem here
- 237 Nebula Ideas
- 6.8K Security
- 744 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
