which Zyxel firewall can i used for hotel apartment?
Hi @usman,
In order recommend you a firewall to match requirement for hotel apartments, we also need to know if you need Hotspot and AP controller features.
If you need AP controller feature only, you can consider ATP800 or USG FLEX 700.
If both Hotspot and AP controller features are required, we suggest you use USG FLEX 700. (Note: ATP800 doesn't support Hotspot feeature.)0
Hi @usman,
If both Hotspot and AP controller features are required, we suggest you use USG FLEX 700. (Note: ATP800 doesn't support Hotspot feeature.)0 -
USG FLEX 700 with hotspot licence and UTM security; in same scenario ,and don t forget to handle managed switch layer 3 and 2
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 501 USG FLEX H Series
- 323 Security Ideas
- 49 Wireless Ideas
- 287 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
