"Full tunnel mode" missing from SSL VPN
Device is USG20W-VPN (now rebranded as USG Flex 50W), started with a ZLD 4.x firmware.
Now has latest available firmware, 5.37. Is working nice as L2TP gateway.
Tried to deploy SSL VPN with 4.0.5.0 client. I cannot connect; something is missing, IMVHO.
On this PDF, provided as walkthrougth from the firmware
seems that I need to check a box called "Enable Network extension". Image from that PDF.
however, accessing to the device, i have no checkbox with that option.
Nor into
-already existing connection
-new connection
-using firefox
-using chrome
-after a refresh
So: how can I enable that option now?
When it will reappear?
For more troubleshooting: i can login with an SSL-enabled user, i cannot connect using the client and i receive no log reference for "errors" about username or whatsoever.
Also: no signaling from the client that the certificate is "unsafe".
Maybe it enabled by default?
I can connect to my VPN300 SSLVPN with 4.0.5.0 client fine without that option
Thanks for your experience, however I don't have the same behaviour.
Your link for VPN walkthrough provide the same PDF?
UP. And solution. Ish.
What I did wrong: input the wrong port into SSLVPN tab (Configuration → VPN → SSL VPN → Global setting → SSL VPN Port)
SecuExtender was not communicating to SSL VPN Daemon on USG Flex 50, missing dialog of the certificate (is stock) should have triggered warning signal to me.
After correcting port number, I access without issues to SSL VPN.Unfortunately PDF is still a bit misleading.
What's missing as option: network translation, like L2TP provides as destination NAT. That's a bit unfortunate.
Last but not least: SecuExtender seems uncapable to establish a connection while Sophos home is installed.
would seem out dated
To say the least. Should be fine for ZLD 4.x firmwares. But 5.x firmware were released… 2021/04/12 according to release notes available here.
https://download.zyxel.com/USG_FLEX_100/firmware/USG%20FLEX%20100_5.37(ABUH.1)C0_2.pdf
Page 59.
I mean it's a 32 months "whopps" interval. ;-)0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
