Vpn wit 2 local lan
Hello
I have a VPN between 2 zyxel VPN100 and works fine.
The local lan is 192.168.1.0 for the on and 192.168.0.0 for the other
Now i have another lan with 192.168.2.0 for the first and 192.168.3.0 for the oter on other port of firewalls. How can i set up a vpn also between?
It's possible? Thanks
So you need to setup another site to site for them LAN's
Make sure you don't have a LAN enables with the same subnet on both VPN100
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
