Port 80 foward
T_G
T_G Posts: 13  Freshman Member
First Anniversary 10 Comments
edited January 18 in Security
i have some ports to open but the 80 give me a problem.
I have set the foward, i change the default port on system→www→http but the ports not work,
Some helps?
«1
    PeterUK Posts: 2,809  Guru Member
    First Anniversary 10 Comments Friend Collector First Answer
    Have you done NAT rules?
  • T_G
    Yes
    Does your ISP allow port 80? does the USG have the WAN IP and that your not behind another router doing NAT?
  • T_G
    I'm behind a fritz box 7590 in exposed host mode. Https works because i login in firewall and also the other ports. I also try to foward on fritz box the port 80 on firewall.
  • smb_corp_user
    smb_corp_user Posts: 161  Master Member
    Maybe I have misunderstood, I could be completely missing the point, but anyway:
    I thought the interface wan1 would be your connection to/from the Fritz box / ISP / internet, and you would have to access the Zyxel via one of the LAN ports. Then again, I may have misunderstood your network.
  • T_G
    Hello
    I have a fritz box as router. Then the firewall for 2 lan. The router have a mode called 'exposed' that open all port to 1 device (the firewall). I need to see the Port 80 from external to server on a lan. For the other ports hat I have opened it works, but for the 80 not.
  • T_G
    I have maked a test. I set from frizbox port foward on a test pc with webserver connected directly. And works.
    If i set the same port on the firewall it not works, so the ISP not block the port.
    edited January 19
    Do a packet capture on the USG for port 80 and do a port scan to see if it hit the USG
    https://www.grc.com/x/ne.dll?bh0bkyd2
    One other thing you can try but really you only do this for other reason is make a service group with HTTP and use that in your NAT rule for port mapping type.
  • T_G
    I have maked a test, it tell me "Stealth"
    edited January 19
    Yes but is the traffic getting to the USG, go to diagnostics > packet capture move WAN1 in capture interfaces and set host port to 80 and capture then go to GRC and scan for port 80 stop capture then go to files and open the .cap file for WAN1 you should see from 4.79.142.206 a TCP SYN to port 80
Security Highlight
