Port 80 foward
Have you done NAT rules?
Yes
Does your ISP allow port 80? does the USG have the WAN IP and that your not behind another router doing NAT?
I'm behind a fritz box 7590 in exposed host mode. Https works because i login in firewall and also the other ports. I also try to foward on fritz box the port 80 on firewall.
Maybe I have misunderstood, I could be completely missing the point, but anyway:
I thought the interface wan1 would be your connection to/from the Fritz box / ISP / internet, and you would have to access the Zyxel via one of the LAN ports. Then again, I may have misunderstood your network.
Hello
I have a fritz box as router. Then the firewall for 2 lan. The router have a mode called 'exposed' that open all port to 1 device (the firewall). I need to see the Port 80 from external to server on a lan. For the other ports hat I have opened it works, but for the 80 not.
I have maked a test. I set from frizbox port foward on a test pc with webserver connected directly. And works.
If i set the same port on the firewall it not works, so the ISP not block the port.
Do a packet capture on the USG for port 80 and do a port scan to see if it hit the USG
https://www.grc.com/x/ne.dll?bh0bkyd2
One other thing you can try but really you only do this for other reason is make a service group with HTTP and use that in your NAT rule for port mapping type.
I have maked a test, it tell me "Stealth"
Yes but is the traffic getting to the USG, go to diagnostics > packet capture move WAN1 in capture interfaces and set host port to 80 and capture then go to GRC and scan for port 80 stop capture then go to files and open the .cap file for WAN1 you should see from 4.79.142.206 a TCP SYN to port 80
- 396 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 86 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 916 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 912 Nebula FAQ
- 419 Security FAQ
- 237 Switch FAQ
- 207 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
