DNS resolution over VPN Ipsec from windows
My VPN connection working.
I have a problem with dns resolution:
My server :
SERVERDATA.DOMAIN.LOCAL = 192.168.5.10
Ping 192.168.5.10 : ok
Ping serverdata.domain.local : ok
ping serverdata : not ok
Inside network it works.
I prefere do not enter manualy the dns sufixe in windows 11.
In my zyxel i have a forward zone : all to 192.168.5.11 (dns server)
Have you a solution ?
  • smb_corp_user
    smb_corp_user Posts: 172 image  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    OK, so you expected to be able to make a DNS name lookup only on hostname, instead of using fully qualified domain name (FQDN). Has it worked previously?
    I would not expect hostname DNS lookup to work other than on the same LAN subnet, but maybe I have missed something. Maybe there is a way to make it work over VPN, I have forgotten.
  • QuiteSmart
    QuiteSmart Posts: 68 image  Ally Member
    Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - WLAN
    have you tried inserting domain.local in:
    configuration —> system —> host name —> domain name
  • Zyxel_Cooldia
    Hi @crsdg ,
    When you ping 'serverdata,' it initiates a NetBIOS name query, not a DNS query.
  • smb_corp_user
    Excellent point. Configure local DNS to map the hostnames to IP addresses to traverse subnets.
