DNS resolution over VPN Ipsec from windows
My VPN connection working.
I have a problem with dns resolution:
My server :
SERVERDATA.DOMAIN.LOCAL = 192.168.5.10
Ping 192.168.5.10 : ok
Ping serverdata.domain.local : ok
ping serverdata : not ok
Inside network it works.
I prefere do not enter manualy the dns sufixe in windows 11.
In my zyxel i have a forward zone : all to 192.168.5.11 (dns server)
Have you a solution ?
OK, so you expected to be able to make a DNS name lookup only on hostname, instead of using fully qualified domain name (FQDN). Has it worked previously?
I would not expect hostname DNS lookup to work other than on the same LAN subnet, but maybe I have missed something. Maybe there is a way to make it work over VPN, I have forgotten.
have you tried inserting domain.local in:
configuration —> system —> host name —> domain name
Hi @crsdg ,
When you ping 'serverdata,' it initiates a NetBIOS name query, not a DNS query.
Excellent point. Configure local DNS to map the hostnames to IP addresses to traverse subnets.
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 468 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
