ZyWALL 2plus - not able to get connected to HTTPS interface
Hello ZYXEL Communitiy,
Please don't ask the question from which museum I have a Zywall 2plus
but I have one at a customer site and he wouldn't change this, because it's enough for his needs
Challange
I've forgotten to disable the SSLv3 (Remote Admin trough HTTPS) and now, i've no device that is supporting SSLv3 and gave me a short connection to disable remote management by SSLv3 and set only HTTP for management (i know it's unsecure, but the device is in a network, where a pre-authentication is required to access the interface)
Does anyone have an idea how to connect to a Zywall 2plus without consolecable and disable HTTPS for remote management?
Thanks and best regards
Christian
Challange
Christian
Dear @ChristianG
Is SSH/telnet not an option ?
if so then the command
ras> sys server acces https wan1 off
This disables then the HTTPS server on wan1 , here u also can choose lan, dmz etc.
hello @Mark
Thanks for the quick answer. Do you have any experience whether the access via e.g. putty (or whatever) after switching off the sslv2 protocol? The zywall shouldn't care, should it?
i will test SSH/telenet option at the next onsite visit. And if it is interesting for you, also gladly report about the result
Regards
Christian
Hello @Mark
with SSH (v1) we are able to get connected to the zywall 2plus.
i've disalbed https as described in your post.
But by useing the http link, the system doesn't get connected to the zywall 2plus
is there a short way to enable a rule to access the management interface from LAN to ZYWALL?
Thanks forward
Christian
@Mark
i'm glad for your quick response. the command is working (no error message, but the webinterface is not reachable by FF or Edge browser from a Win10 desktop OS.
Any other idea's to get successful connected to the ZYWALL 2plus ?
After set firewall off and chhange the settings for HTTP and HTTPS, the following config is running, but no access trough brwoser possible
Any idea, or is a old system required (e.g. old WinXP) to get connected trough HTTP ?
Thx forward and best regards
Christian
@ChristianG
Can you PM your telephone number ..
Will call you then tomorrow to discuss some things or possible do a remote session0 -
Solved today together:-) @ChristianG1
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 468 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 441 News and Release
- 4.3K FAQ
- 93 Security Highlight
