How to configure DHCP options in CLI
kruess
According to the Zyxel KB's, it is possible to configure the DHCP options at least by CLI. Could you please elaborate on that one? Thanks.
Hello @kruess
This Web-GUI feature will be supported on future firmware. You can use the below example CLIs to set DHCP options.
usgflex200hp> edit running
usgflex200hp running config# vrf main dhcp server subnet 192.168.168.0/24 dhcp-options0
Hello @kruess
usgflex200hp running config# vrf main dhcp server subnet 192.168.168.0/24 dhcp-options0 -
Hi Jeff, thanks for the hint, I've managed to get the most urgent settings back in place, now, following your examples…
- 431 Beta Program
- 2.6K Nebula
- 164 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
