USG FLEX H – GUI is cumbersome to use
PhilippeB
PhilippeB Posts: 18 image  Freshman Member
The new GUI, as it is currently presented, is a total step backwards. Do we really have to select every rule to be changed via the checkbox before we can edit it?
The previous drop-down menus were never particularly sophisticated, but compared to the cumbersome editing functions in the FLEX H series, I already sorely miss the old menus.
Can anyone explain the advantages of the new menu? Is there perhaps an idea behind it that the devices should be programmed with a touch screen in future?
Best Answers
  • Zyxel_Emily
    Hi @PhilippeB,
    In the next version 1.20, you can double click on the rule directly without selecting the checkbox and clicking "Edit".
  • Zyxel_Emily
    edited January 2024 Answer ✓
    Hi @kruess,
    • 1.20 release plan: Late Apr. 2024
    • In 1.10, CLI for DHCP extended options is supported. Configuration on web GUI will be supported in the future release.
    usgflex200h> edit running
    usgflex200h running config# vrf main dhcp server subnet <subnet> dhcp-options
    usgflex200h running dhcp-options# dhcp-server-identifier
    • UX is improved in 1.20. Here is the layout of 1.20 for your reference.
  • Zyxel_Emily
    Hi @PhilippeB,
  • kruess
    kruess Posts: 20 image  Freshman Member
    First Comment First Answer Friend Collector Fourth Anniversary
    Ufff, and when will v1.20 be available? Will it also contain the DHCP Options?
    What about a more condense layout? Currently, the GUI is loosing soooo much valuable space by all that empty room (ie between the lines, etc) and requires much more scrolling compared to the GUI of the previous models (ATP).
  • Zyxel_Emily
    Hi @kruess,
  • kruess
    Hi Emily
    Thanks for the code snippets - I've been able to adopt those to our urgent DHCP fine-tuning requirements. Interestingly, the "user-defined" options only allow 3 params (code#, type, value), but usually (and also on the ATP/USG series) that one consisted of 4 params (name, code#, type, value).
    Also, I could not figure out how to add several IP addresses to the option "ntp-server". I've tried to separate those with ' ' ';' ',' or add " around the value list, but it did not work.
    BfN, Konrad
  • PhilippeB
    Hopefully version 1.20 will also contain many corrections, because the GUI crashes regularly and often there is no other option but to restart the device.
  • kruess
    edited February 2024
    Yeah, it's awful to work with this GUI. So many missing things, unexpected behaviour, instabilities - even instabilities of the device itself, not only the GUI…. :-((( It's kind of pre-alpha state, but already sold as the gadget. 😬
  • Zyxel_Emily
    Hi @PhilippeB,
    Which USG FLEX H model are you using? We can send the firmware with several bug fixes to you in private message to verify the GUI crash issue.
  • Zyxel_Emily
    Hi @kruess,
    Which USG FLEX H model are you using? We can send the firmware with several bug fixes to you in private message to verify stability issues.
  • PhilippeB
    We'll be very happy to try it. It is a FLEX 200H (we have it running with firmware 110ABWV1ITS-23WK50-r288617f4).
  • PhilippeB
    Another thing is the new dropdown menu which always appears in the right bottom of the screen. On huge screens it's a little bit strange:
