How to configure DHCP options in CLI
kruess
According to the Zyxel KB's, it is possible to configure the DHCP options at least by CLI. Could you please elaborate on that one? Thanks.
Hello @kruess
This Web-GUI feature will be supported on future firmware. You can use the below example CLIs to set DHCP options.
usgflex200hp> edit running
usgflex200hp running config# vrf main dhcp server subnet 192.168.168.0/24 dhcp-options0
Hello @kruess
usgflex200hp running config# vrf main dhcp server subnet 192.168.168.0/24 dhcp-options0 -
Hi Jeff, thanks for the hint, I've managed to get the most urgent settings back in place, now, following your examples…
- 435 Beta Program
- 176 Nebula Ideas
- 119 Nebula Status and Incidents
- 431 USG FLEX H Series
- 299 Security Ideas
- 79 Switch Ideas
- 276 Service & License
- 428 News and Release
- 89 Security Highlight
