Will Zyxel discontinue local management via APCs
technikhirscher
technikhirscher Posts: 2
edited May 2024 in Wireless
Will Zyxel discontinue local management via APCs and only offer management via the cloud aka nebula or via a firewall?
I didnt find any products listed for NXCs on the Zyxel-Website.
  • Zyxel_Kay
    Hi @technikhirscher
    Currently, the model series that continue to support APC technology are ATP, USG FLEX, and VPN series. Unfortunately, the NXC series has reached its end of life, and it will no longer receive support.
    Regarding AP management modes, there are three options: Nebula cloud mode, controller mode, and standalone mode. For local management, you may consider the controller mode with models that support APC technology or choose the standalone mode.
    For more information about the models that support APC technology, please refer to the following link: https://www.zyxel.com/global/en/products/wireless/apc-ap-controller-technology/support
    Kay
  • Zyxel_Kay
    Hi @technikhirscher
    Kay
