UDP Session Timeout | USG Flex 200HP
DJS
DJS Posts: 1
edited January 2024 in USG FLEX H Series
Hi
Where can I change the session timeout for udp-delivery and udp-connect on a new USG FLEX 200HP?
In the old version there was a command for this but it no longer works.
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 981 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    edited January 2024 Answer ✓
    Hi @DJS ,
    Greeting Forum,
    We will support TCP/UDP timeout in next version 1.20 in GUI
    For currenty version, Please kindly find the following CLI
    200h>edit running
    200h running config#system network-stack conntrack udp-timeout-stream <seconds>
    ; You can find some paremeter which you want after system network-stack conntrack
    ; udp-timeout-stream equal udp-delivery
    200h running config#commit
    200h running config#copy running startup
    200h running config#show state system network-stack conntrack
    Thank you
  • Zyxel_Kevin
    Hi @DJS ,
    Greeting Forum,
    200h>edit running
    Thank you
