Block Configuration ipv4 / 29
virtualware
My configuration:
1 OVH XDSL box in bridge mode with an additional ipv4 / 29 block that is connected to the WAN1 of a USG 100.
I have several virtual machines (DNS server, WEB server, MAIL server, SQL server .....) that currently works on the DMZ leg in NAT on the main IPV4 address of the OVH box.
My question
Is it possible or rather how to assign my block IPV4 / 29 (6 ipv4) directly on the DMZ leg to assign them to my different virtual machines without doing NAT.
Thank you for your help
Sebastian
My configuration:
My question
Sebastian
The similar case already been discussed before.
For Zyxel USG60 unified security gateway, how can we set it to have private LAN & pubblic IPs in DMZ
The rule also need to be created Wan >DMZ with requested service which virtual server using on security policy
Thank you I'll see her right now
- 602 USG FLEX H Series
- 480 News and Release
