Can't register or update GS1920-24 (v1?)
crls
crls Posts: 2 image  Freshman Member
edited August 2022 in Switch
I have a gs1920-24, not the v2 version, the v1, its really hard to find information and for now I haven't been able to find a newer firmware version than the one its running:
System Name gs1920
Product Model GS1920-24
ZyNOS F/W Version V4.10(AAOB.4) | 09/16/2014
Ethernet Address 4c:9e:ff:7d:30:57
I also get this in "myzyxel" site but there is not registration option in the switch menus.
Please help
  • Zyxel_Jason
    Zyxel_Jason Posts: 428 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
    Hi @crls,
    Welcome to Zyxel Community!
    Since GS1920 v1 series is end of life, please click this link to check the list and download the last firmware of GS1920-24 (V4.50(AAOB.3)).
    Here is another location that you may enter the EOL list:
    Hope it helps.
    Jason
  • Zyxel_Jason
    Hi @crls,
    Hope it helps.
    Jason
  • crls
    Jason you are the man!
    I knew it was EOL but couldnt find the website you pointed me towards. Now it works:
    Thank you!!
  • SoluzioniDigitali
    SoluzioniDigitali Posts: 6 image  Freshman Member
    First Comment Seventh Anniversary Nebula Gratitude
    Good Morning Ihave the same Problem with a customer. GS1920-24 v1. I checked the EOL list , but there this model there is not… or there isn't anymore.
    Where can I download the last firmware. Now I have a 4.30(AAOB.0)
  • SoluzioniDigitali
    see, there's only the GS1900
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,200 image  Zyxel Employee
    Hi @SoluzioniDigitali,
    We removed it from the end-of-life list since GS1920-24 V1 has ended its life for more than 3 years.
    Please download the latest firmware via this link.
    Zyxel Melen
  • SoluzioniDigitali
    Thank you,.!!!I know, but thi sis what I have.
    When will have the change we willchange it.
  • SoluzioniDigitali
    I guess there's some problem with the link.. or the download .. I see it's a zip file.
    The ownload stay there doing noting :(
  • Zyxel_Melen
    Please unzip the file and find the .bin file to upgrade.
    Zyxel Melen
