Import certificate error ATP
Hi @aait
We will merge this fix into 5.37P1 WK firmware, too. It is expected to be released in the middle of January 2024. Thanks.
even the certificate with the .pfx extension is not imported, "errno: -17011 errmsg: PKI certificate type is not supported".. I have a certificate expiring in two days, how can I resolve this?
Hi @aait
Thank you for reporting this case to us. Could you provide a remote Web-GUI to us for further checking? We will send a private message to you later, please check your inbox, thanks.
I'm having the same issue with USG 110, USG40 and USG60 all of them with firmware 4.73 patch 2.
@Zyxel_Jeff any suggestions?
Thank you
Best regards0 -
Hi @aait
We will fix it in the next FCS firmware, thanks.
Hi Jeff,
when will the new firmware be released?
I have several ATP with expiring certificates
Thank you0 -
Hi @aait
We have an ATP 100W and having those issues with applying our pkcs12 pfx cert bundle. Current Firmware 5.37(ABRW.1)C0 is from November 2023, so I guess that fix is not rolled out yet? Our cert runs out in the next few days.
Install patch3, this fixes the certificate import
https://support.zyxel.eu/hc/en-us/articles/360005438274
ATP Series 5.37 Patch 3 WK01(2024)
And for USG Series with 4.73? When the patch will be available? Thank you
Best regards0
- 213 Nebula Ideas
- 554 USG FLEX H Series
- 342 Security Ideas
- 295 Service & License
- 471 News and Release
ZCNE Certified
