SSL-VPN behind a other Router
I want to create an SSL-VPN conection between my Computer and my Zywall VPN50. The Zywall is behind a Router. Which Ports do I have to forward and what do I have to change in my router so that it forwards the Traffic to the Zywall? The Zywall is configured as a DMZ in the router and every device at home is connected to the Zywall and not to the router. The DDNS is already configured and I already configured the SSL-VPN. https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=015546&lang=EN
Router:
Public-IP:xxxxxxx
IP:192.168.10.1
Zywall:
wan(dmz): 192.168.10.2
Thank you very much.
@ret
As this scenario, you need to create NAT port forwarding rule on your own device to let SSL VPN connection be established. The attached SOP as your reference.
Charlie5
@ret
Charlie5 -
@Zyxel_Charlie Thank you very much for your help, but I am still not able to get an connection.The pictures below are showing what I have already configured.
@ret
Did you configure the Nat rule and security policy on your own device(fritz!box)?
I have confirmed on my lab with two USGs and the scenario is working.
Charlie0 -
Unfortunately my router does not offer this option, thank you for your help, but I have to proably buy a modem.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
