ZTP is already enabled. Please report to administrator for troubleshooting.
Please refer to this FAQ : How to solve the issue "ZTP is already enabled" on VPN series? Please download the 537ABHL1ITS-24WK05s-r112483.bin firmware and update it by FTP. Thanks.
Have same issue, seems to be global zyxel bug or hacker attack
Any answer from zyxel?
We are stuck. It's a big problem
Reset can be a solutions?
Hi @T_G
May we know which Zyxel firewall model and the firmware you are using now? Is it USG Flex/ATP/VPN series model? We need the exact information. Thanks.
Hi @T_G
We sent a private message to you, please check your inbox. Thank you.
Hello @T_G
Please refer to this FAQ: How to solve the issue "ZTP is already enabled" on VPN series? Thanks.
please help!
we need to return the old mode of operation so that there is no SD-WAN.all work stopped.
Zyxel VPN50.
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
