Templates for USG series routers
TAPTech
It would be great if we could create importable templates for the USG series routers. We are an MSP and often deploy common services to clients. For example, we deploy a cloud VoIP solution. For every client site that has this, we need to configure BWM rules and service Object and Groups for their USG. They are all identical. At times we need to tweak them, and it would be great to just update all of the units via a template.
@TAPTech
You can set appropriate configuration for your scenario, and download the configuration(startup_config.conf) as your templates.
If you need to deploy the similar environment on other sites, you just upload the configured templates to units.
Charlie0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
