USG - Configuration Backup by Mail
ChrisGer
ChrisGer Posts: 206  Ally Member
Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula
edited July 2024 in Security Ideas
Hi ZYXEL Team,
USG's are able to send reports/alytes allreday, wouldn't it be an option to adapt the option to send also the  startup.conf by mail to a mailbox? so you could set up an automated backup on existing modules (ok, must be a bit extended) ?
From ZYXEL's point of view, is this a solution for regular, automated backup of the current/running configuration on a USG?
Regards
Christian
0 votes
Active · Last Updated
  • ChrisGer
    @Plats
    but it's no an official option by ZYXEL ;) ? Mail and Log reports are allready send by mail, so it's not a complete new part to send a backup of the running config by mail - i see this as a extention of the existing mail module.
    Regards
    Christian
  • Plats
    Plats Posts: 12  Freshman Member
    First Comment Sixth Anniversary
    I do agree. The mail option should be easy to implement and would be a nice feature.
    The reason i said the FTP option, is that it is something that works right now. New features can be some time away :)
  • TAPTech
    TAPTech Posts: 174  Master Member
    First Comment Friend Collector Seventh Anniversary Nebula Gratitude
    Great idea!
  • ChrisGer
    @Plats and @TAPTech
    i have a nice feature if the cfg is sent by mail :)
    It's called "Encryption password" :)
    The admin is forced to set an "Encryption Password", so that the config is made "unreadable" before the verse with this password.
    Of course you should know the "Encryption password" during restore. ?
  • Zyxel_Joshua
    Zyxel_Joshua Posts: 62  Zyxel Employee
    Zyxel Certified Network Administrator - Security 5 Answers First Comment Friend Collector
    In ZLD 4.60, it support to schedule backup the "startup-config.conf" with encryption password via mail.
  • ChrisGer
    will upgrade today and check the auto config backup via mail" =)
    if the upgrade and function is successful, i leave a post in this thread.
  • ChrisGer
    update to 4.60 run well and no side effect messages trough console where shown =)
    thank for implementing the feature =)
