Re-direction to external IP address
BruJoe
BruJoe Posts: 2
Zyxel Certified Network Administrator - Security First Comment
edited February 2024 in Security
Following problem: We have a address (analysis.xyz.com) who is directed to our Zyxel USG110 (192.168.10.1). There the senders IP has to be a valid VPN-user, then he will be forwarded to a internal Server (192.168.20.115).
Now this receiver is an external server (82.195.236.xxx). How to configure the Zyxel so the forwarding is no more internal but to the external address?
Thanks for help!
  • BruJoe
    BruJoe Posts: 2
    edited February 2024 Answer ✓
    Solved. The security policy was wrong… But thx!
    PeterUK Posts: 4,228 image  Guru Member
    So can't you make analysis.xyz.com device send to 82.195.236.xxx instead of to 192.168.10.1 ?
    I'm guessing there is a NAT rule to forward from 192.168.10.1 down the VPN to 192.168.20.115 ?
    are the ports 443 and 80 for this traffic?
  • lalaland
    lalaland Posts: 91 image  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    Can you share more information about your scenario?
  • BruJoe
    BruJoe Posts: 2
