Hard reset usg20w-vpn
Unless I'm mistaken, it seems to me that when a usg is first commissioned, the router is loaded with "minimal" firmware and downloads the latest standard firmware.
When I reset my usg20w-vpn, I find remnants of previous configurations, such as a personalized home page with an image.
I'd like to know if there's a minimum firmware or if it's possible to do a reset, not just of the configuration, but of a deeper level, like when I left the factory.
Thank you in advance for your help.
AFAIK even the deepest reset will leave some older configuration files into the device, which can be deleted.
Any kind of reset should remove logos (file and config), unless someone replaced the original zyxel logo file with a different image.
The factory default still keeps backup configuration files, certificates, and some other files. Holding down the RESET button performs an action similar to copying the system default configuration to the startup configuration file.
Thanks for the information. I would have liked to be able to do an "out of the box" reset with no trace of files or anything. Not being an expert, I thought that in the case of an undetected intrusion, it would be the assurance of starting again on a clean system.
Hi @c777
You might want to consider recovering the system database. This process can reset all configurations to their default state, essentially making it like a new system.
Hi Zyxel_Stanley
Thanks a lot, I'll give it a try.
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 511 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 288 Service & License
- 458 News and Release
- 4.3K FAQ
- 97 Security Highlight
