Switch GS1900 Series - V2.80 Patch 0 Firmware Release
Zyxel_Melen
Zyxel_Melen Posts: 4,533 image  Zyxel Employee
edited August 2024 in Switch New Release
Zyxel Switch GS1900 Series
Release Note
October, 2023
Firmware Version on all models
(Click Hyperlink to download the firmware directly)
Zyxel GS1900-8        - V2.80(AAHH.0)
Zyxel GS1900-8HP      - V2.80(AAHI.0)
Zyxel GS1900-8HP(Rev. B1)  - V2.80(AAHI.0)
Zyxel GS1900-10HP          - V2.80(AAZI.0)
Zyxel GS1900-16            - V2.80(AAHJ.0)
Zyxel GS1900-24E         - V2.80(AAHK.0)
Zyxel GS1900-24EP         - V2.80(ABTO.0)
Zyxel GS1900-24           - V2.80(AAHL.0)
Zyxel GS1900-24HPv2        - V2.80(ABTP.0)
Zyxel GS1900-48           - V2.80(AAHN.0)
Zyxel GS1900-48HPv2       - V2.80(ABTQ.0)
New Features and Enhancements
  1. Support importing HTTPs Certificate.
  2. To enhance security, a default password change will be mandatory when logging into web interface.
  3. [eITS#230800658] Switch sends tagged/untagged ZDP packets to ZON Utility based on the VLAN egress rules.
Bug fix
  1. [eITS#230201247] Fixed OpenSSL related vulnerabilities. [CVE-2022-4304][CVE-2023-0215][CVE-2023-0286]
  2. [eITS#230700106] Fixed improper access control vulnerability via web GUI.
  3. [eITS#230500345] Fixed stopping power delivery issue on PoE switch models.
  4. [eITS#230200111] Fixed the issue of cross-routing access being unavailable when the switch uses a Unique Local IPv6 Address.
  5. [eITS#230500459] Fixed the issue where changing the SFP port speed from 100M to 1000M would result in a switch port link going down.
Please refer to the Download Link for more details.
Zyxel Melen
  • Hi, I'm getting a Firmware Validation Error. Since you don't provide checksums can you please verify if this is correct ?
    6a20f70d26cc5932e6d3a4fc1a140befeb664aa4  GS1900-48HPv2_2.80(ABTQ.0)C0.zip
  • Zyxel_Melen
    Hi @Edgar_Naudé,
    Your checksum is correct. However, to upgrade your GS1900-48HPv2, you have to unzip it and upload the runtime-xxx.bix file.
    Zyxel Melen
