after ssl connect with secuextender, client cannot see lan1
Hello @Zyxel_Emily
I just upgraded my USG60W to V4.32(AAKZ.0) and am experiencing the exact same issue.
Could you please share the fix ?
Many thanks in advance.
Kind regards0 -
Still the same Problem with vpn100 10.01(ABFV.1) and Secuext 4.0.3. The Problem exist since Oktober! When will it be definitly be fixed???0
Hi Emily,
same problem on a USG110, could you send me the firmware?
Hi @BreitNet8610
This issue will fix in next version 10.02. And the schedule will at around end of Jan.
@LucaTabo
The firmware is sent to you via private message.
USG110 - Firmware 4.32 - Same issue. Windows 10, TAP driver (version 9) stays on default IP, and not range of VPN.0
Hello.
Same issue here. USG60 4.32, SecuExtender 4.0.2.00 -
- 244 Nebula Ideas
- 6.9K Security
- 808 USG FLEX H Series
- 392 Security Ideas
- Threat Watch!
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
