Where is SNAT?
Our US suppliers are showing that the only available units are this new H series. We purchased one thinking it was simply "hardware only" because otherwise everything is bundled with licenses. What we found is this new cut down interface with critical features missing.
Calling in to the support line was even less helpful - the tech could not provide any information on what else was removed, simply saying "If you don't see it, its not there, we might add it in the future"
What is going on with this model line and is it fully replacing the non H series in the US?
  • SecureTechInovations
    Sale engineer confirmed:
    currently the USG FLEX H doesn't support SNAT/DNAT functions on the VPN as of yet. This is something that will be added in the next major firmware update in April.
