Port blocked?
Hello there! I'm sorry if this is in the wrong section.
Quick recap.
I use:
Synology Nas - nighthawk R8000 - zyxel NR7103 with mobile connection.
Before I bought the NR7103 and use land line I had no issues, the port 5000-5001 is open on nighthawk. Nas has static ip from nighthawk.
But when I plugged in the NR7103 I can't access it external anymore.
I updated the dns in synology for the new ip and it also have quick connect. Every port is closed.
I checked in the zyxel router and from what I understand it give my nighthawk router the internet ip adress and don't handle any traffic but I still can't access the ports when I use the mobile router as modem.
Any suggestions? Would save my life 😏.
You have given up your land line with a WAN IP that a NR7103 by ISP uses CGNAT so no inbound traffic will happen.
2
2 -
Yea.
I found the issue.
But the offer static ip, so I bought one. Hopefully that will fix my issue 😊
But thank you alot for your help!
- 438 Beta Program
- 189 Nebula Ideas
- 6.2K Security
- 458 USG FLEX H Series
- 304 Security Ideas
- 81 Switch Ideas
- 280 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
