Switch GS1900 Series - V2.80 Patch 0 Firmware Release
Zyxel Switch GS1900 Series
Release Note
October, 2023
Firmware Version on all models
(Click Hyperlink to download the firmware directly)
Zyxel GS1900-8 - V2.80(AAHH.0)
Zyxel GS1900-8HP - V2.80(AAHI.0)
Zyxel GS1900-8HP(Rev. B1) - V2.80(AAHI.0)
Zyxel GS1900-10HP - V2.80(AAZI.0)
Zyxel GS1900-16 - V2.80(AAHJ.0)
Zyxel GS1900-24E - V2.80(AAHK.0)
Zyxel GS1900-24EP - V2.80(ABTO.0)
Zyxel GS1900-24 - V2.80(AAHL.0)
Zyxel GS1900-24HPv2 - V2.80(ABTP.0)
Zyxel GS1900-48 - V2.80(AAHN.0)
Zyxel GS1900-48HPv2 - V2.80(ABTQ.0)
New Features and Enhancements- Support importing HTTPs Certificate.
- To enhance security, a default password change will be mandatory when logging into web interface.
- [eITS#230800658] Switch sends tagged/untagged ZDP packets to ZON Utility based on the VLAN egress rules.
- [eITS#230201247] Fixed OpenSSL related vulnerabilities. [CVE-2022-4304][CVE-2023-0215][CVE-2023-0286]
- [eITS#230700106] Fixed improper access control vulnerability via web GUI.
- [eITS#230500345] Fixed stopping power delivery issue on PoE switch models.
- [eITS#230200111] Fixed the issue of cross-routing access being unavailable when the switch uses a Unique Local IPv6 Address.
- [eITS#230500459] Fixed the issue where changing the SFP port speed from 100M to 1000M would result in a switch port link going down.
Please refer to the Download Link for more details.
Hi, I'm getting a Firmware Validation Error. Since you don't provide checksums can you please verify if this is correct ?
6a20f70d26cc5932e6d3a4fc1a140befeb664aa4 GS1900-48HPv2_2.80(ABTQ.0)C0.zip
Hi @Edgar_Naudé,
Your checksum is correct. However, to upgrade your GS1900-48HPv2, you have to unzip it and upload the runtime-xxx.bix file.
Zyxel Melen0
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
