XMG 1930 limit admin support web access to physical port 1
Zusexcel
Zusexcel Posts: 2
edited February 2024 in Switch
I just got my XMG1930 unfortunately, it does not have a service port like
my Cisco switch, so at least I want to limit the admin web service access to port 1. I cannot find any way to do this.
    Limit it by VLAN and or ACL maybe?
  • Is there no direct hardwarebase limitation like on Cisco switches?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,604 image  Zyxel Employee
    Hi @Zusexcel,
    I'm not familiar with Cisco Switch's service port. Is your purpose that port 1 can access the web GUI but cannot access other ports? And the other ports cannot access the web GUI?
    By the way, could you share the Cisco switch model you have?
    Zyxel Melen
