DHCP Table - edit host names
eddyshere
eddyshere Posts: 15
image  Freshman Member
edited February 2024 in USG FLEX H Series
When will the host names in the DHCP table be editable ?
Having a huge DHCP Table with dozen of reservations it is a real pain without being able to enter a meaningfull host name.
I know firmware is planned for april 2024 but let's be honest here H series (uOS) was just not ready to be sold and i feel trapped now even more having 1 active gold abo for H series and i have not renewed on the regular flex500!
At least I did not change all the Zywall's we run but time is maybe right to search for alternatives
If new firmware is planned within a 5 month release cycle….come on ?!?…
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 988
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    image  Zyxel Employee
    Hi ,
    We are going to support edit host name in next version.
    And upcoming in Apr.
    Thank you
  • Zyxel_Kevin
    Hi @eddyshere ,
    Greeting Forum, Firewall learns the hostname from DHCP client reqest.
    We don't have option can modify hostname on GUI and CLI currently.
    Thank your suggestion we will evaulate the feature.
    Kevin
  • eddyshere
    eddyshere Posts: 15
    No need to evaluate please FIX the feature then.
    I'm talking for RESERVED ip's. currently the firewall attributes automatically the name : host_xxx.xxx.xxx.xxx
    so either it discovers these also right or if not possible give a way to edit the automatically displayed name
    PeterUK Posts: 4,749
    image  Guru Member
    So the FLEX can display a host name from DHCP but as soon as you reserve it goes to host_xxx.xxx.xxx.xxx its some what not a bug just what happens when you do a reserve.
    What you want is a label or yes the DHCP server with the reserve listing to show from DHCP the host name like it does without a reserve.
  • Zyxel_Kevin
    Hi @eddyshere ,
    Sorry for the misunderstood,
    Currently you can use CLI to define the Host Name. Please kindly find the command:
    #edit running
    #vrf main dhcp server {subnet} host {your hostname} {MAC_Addr} {IP}
    #commit
    For example:
    #vrf main dhcp server 192.168.1.0/24 host TESTUSER 00:00:00:11:11:11 192.168.1.4
    Thank you
  • bbp
    bbp Posts: 70
    First Answer First Comment Friend Collector Seventh Anniversary
    image  Ally Member
    That won't parse, you have to use quotes, like this:
    vrf "main" dhcp server subnet "192.168.12.0/24" host "myhostname-example" "192.168.12.77" "00:00:00:00:00:00"
  • teun_jrit_nl
    That way is not working. The new update in April will add the description per device like in the other firmwares.
  • Zyxel_Kevin
    Hi ,
    Thank you
  • eddyshere
    eddyshere Posts: 15
    1.20 installed : THANK YOU for the functionality
  • bbp
    bbp Posts: 70
    image  Ally Member
    There is a bug with Description Column. When you select description column, the change doesn't stick. You have to select it every time you view DHCP table. It should remember the setting.
