ugly bug in IPV6 config part of latest XMG1915-10E switch firmware?
cbeckstein
cbeckstein Posts: 22
image  Freshman Member
edited February 2024 in Switch
2 new XMG1915-10E, both with latest V4.80(ACGO.1) firmware, configured standalone:
(IP, DNS et al via DHCP and DHCPV6 active on VLAN 1, just one VLAN with ID 1)
on both, almost always when I try to ask for details of the IPV6 status of vlan 1
(System - IPV6 - IPV6 Status - click on the only VLAN with index 1)
the switch crashes and takes several minutes to come up and be usable again:
NO system: System cold start
IN system: Image 2 F/W version V4.80(ACGO.1) | 08/31/2023 boot up
AL system: System has reset without management command
otherwise switch works fine with IPV6
PS: one more info about the config:
IPV6 config data (DNS, IA_PD, and IA_NA) comes from fritzbox (DHCP rapid commit set),
switches are set as DHCP6 clients with IA_NA, rapid commit, DNS and Domains enabled
Anybody else with this ugly problem?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,877
    image  Zyxel Employee
    The issue you're experiencing will be addressed in the upcoming firmware update. Please stay tuned for further announcements regarding enhancements and fixes.
    Zyxel_Judy
