SSH: Implement SSH Public Key Authentication
I have got a suggestion for future ZyNOS releases:
It would be great to be able to log into the switch using an SSH Pubkey instead of password.
Using pubkeys would increase security (especially combined with a possibility to disable password auth for SSH) and make scripting/automation easier as wrappers like sshpass would be no longer required.
Best regards,
// Veit
Whatever happened with this? Was it ever implemented anywhere?0
Hi @danyedinak ,
Thanks for following up on this.
Although we understand the benefit of offering SSH public key authentication and we’ve already add it to our roadmap, the availability has been pushed out several times due to more urgent project demands.
Jason0 -
Over 3 years later, is there any update on this?
I know that this can be configured with ACS server, but a menu option from the supervisor level would be useful, to see what keys are present and add any manually.
Hi @Tomaszz
We are pleased to inform you that this feature is set to be introduced in the switch V4.90 firmware version.
Since our firmware updates are customized for each switch series, could you please specify the model of the switch you are inquiring about? This will enable us to offer you the most accurate and relevant information regarding availability and implementation.
Kay
Hi Kay,
I am the original author.
We use XGS2210, XGS2220 and XGS4600 series switches.
Best regards,
// Veit0 -
Hi @Veit
SSH public key authentication in ZyNOS4.90 is being implemented in series by series.
We have GS1350 series already support this, following by GS2220 series ( support in Q3’24) and GS1920 series (support Q4’24).ZyNOS4.90 for XGS2200 series will be focus on the new XGS2220 series only, with estimate time frame around Q4’24.
XGS4600 cannot fit in the pipeline for this year, so it will be plan at a later time frame.We apologize for the long waited patience on this as we work to balance new feature request and introduce advanced technology products (2.5G / Multi-gig / 10G) to the Zyxel switch portfolio.
Kay
Hi Kay, is there an a eta when 4.90 will be available for XMG1915 Series?
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
