USG40 - VPN Traffic VPN2Internet/VPN2LAN and back
I set up a IKE VPN with my USG40. The VPN establishing works well, but i don't get any internet or LAN access. In the Logs it looks like the traffic goes through VPN2any, but nothing comes back, but i doesn't see any block in the Log.
What could cause thath error?
Br
Hi @IWAT,
Please send the startup-config.conf to me in private message. Thanks!
Hi Emily
Thanks for you help, but the Startup config contains my whole network with PW.
I would prefer to send you some print screens instead.
Br Iwat0 -
Hi @IWAT,
We will need the whold startup-config.conf to check if all setting are correctly configured. Before sending the configuration file to me, you can remove this line from the configuration file.
"username admin encrypted-password xxxxxx user-type admin"
Your WAN1 being a 192.168.x.x is no need to hide but when clients get 192.168.x.x over the VPN is not conflict with other subnets?
You may need to SNAT VPN traffic out the WAN by routeing rule unless the router upstream of USG40 does static route for the VPN clients that get 192.168.x.x
Hi Peter
The DHCP from the USG is 192.168.2.20 - 192.168.2.200. The VPN gets usually a 192.168.60.xx address, therefore it shouldn't get any conflict. To test it i changed the VPN Adress to 192.168.2.25x, but the error is the same.
Br Ivo0 -
Keep VPN clients on another subnet to not conflict
Change Local policy to 0.0.0.0
Make routing rule
incoming VPN tunnel
next hop WAN
SNAT outgoing-interfacePolicy Control
IPSec_VPN to WAN
and IPSec_VPN to LAN1note that access to a PC on LAN1 may have a firewall blocking you
I have added the Routing rule, the Policy Control has already been created.
But it is still not working.0 -
I have no idea why, but it works now…
- 441 Beta Program
- 210 Nebula Ideas
- 539 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
