VPN stopped working
2»
    edited February 2024
    update
    So from the time 22th 23:50 it stopped working going in a loop of trying to connect to the 23th 02:57 its now connected.... log show a lot of "[COOKIE] Invalid cookie, no sa found"
    edited April 2024
    4 days uptime this happened again there is this problem then there is the other problem the two are not the same where the bridge on VPN300 passes UDP 4500 but VPN tunnel drops it will try and try and likely should connect in some hours on the same IP but still a problem why it not connecting when it should
    from FLEX200
    edited June 2024
    VPN300
    V5.37(ABFC.2)
    Still happing VPN stopped working this is not the same as this
    ^ which I think by me removing the LAG and just having a simple two port bridge has solved that
    VPN just goes in a loop
    2024-06-28 17:21:18
    info
    IKE
    [COOKIE] Invalid cookie, no sa found [count=2]
    10.187.154.135:500
    blank:4500
    IKE_LOG
    2
    2024-06-28 17:21:18
    info
    IKE
    The cookie pair is : 0x7b576d8c225d393a / 0x2f09f7269c493b97 [count=2]
    10.187.154.135:500
    blank:4500
    IKE_LOG
    18
    2024-06-28 17:21:03
    info
    IKE
    Send:[KE][NONCE][PRV][PRV]
    10.187.154.135:500
    blank:500
    IKE_LOG
    19
    2024-06-28 17:21:03
    info
    IKE
    10.187.154.135:500
    blank:500
    IKE_LOG
    22
    2024-06-28 17:21:03
    info
    IKE
    Send:[SA][VID][VID][VID][VID][VID][VID][VID][VID][VID][VID]
    10.187.154.135:500
    blank:500
    IKE_LOG
    23
    2024-06-28 17:21:03
    info
    IKE
    Send Main Mode request to [blank]
    10.187.154.135:500
    blank:500
    IKE_LOG
    24
    2024-06-28 17:21:03
    info
    IKE
    Tunnel [link_to_flex200_4G] Sending IKE request
    10.187.154.135:500
    blank:500
    IKE_LOG
    25
    2024-06-28 17:21:03
    info
    IKE
    The cookie pair is : 0x7b576d8c225d393a / 0x0000000000000000 [count=3]
    10.187.154.135:500
    blank:500
    IKE_LOG
    27
    2024-06-28 17:20:47
    info
    IKE
    10.187.154.135:500
    blank:4500
    IKE_LOG
    28
    2024-06-28 17:20:47
    info
    IKE
    The cookie pair is : 0xca94966c8872f095 / 0xd2190f5a85b316cf [count=2]
    10.187.154.135:500
    blank:4500
    IKE_LOG
    42
    2024-06-28 17:20:29
    info
    IKE
    10.187.154.135:500
    blank:500
    IKE_LOG
    43
    2024-06-28 17:20:29
    info
    IKE
    10.187.154.135:500
    blank:500
    IKE_LOG
    46
    2024-06-28 17:20:29
    info
    IKE
    10.187.154.135:500
    blank:500
    IKE_LOG
    47
    2024-06-28 17:20:29
    info
    IKE
    10.187.154.135:500
    blank:500
    IKE_LOG
    48
    2024-06-28 17:20:29
    info
    IKE
    10.187.154.135:500
    blank:500
    IKE_LOG
    49
    2024-06-28 17:20:29
    info
    IKE
    The cookie pair is : 0xca94966c8872f095 / 0x0000000000000000 [count=3]
    10.187.154.135:500
    blank:500
    IKE_LOG
    58
    2024-06-28 17:20:16
    info
    IKE
    10.187.154.135:500
    blank:4500
    IKE_LOG
    59
    2024-06-28 17:20:16
    info
    IKE
    The cookie pair is : 0x4cbdfa8a11ca935b / 0x3106c9629516c8ad [count=2]
    10.187.154.135:500
    blank:4500
    IKE_LOG
    71
    2024-06-28 17:19:59
    info
    IKE
    10.187.154.135:500
    blank:500
    IKE_LOG
    72
    2024-06-28 17:19:59
    info
    IKE
    10.187.154.135:500
    blank:500
    IKE_LOG
    75
    2024-06-28 17:19:59
    info
    IKE
    10.187.154.135:500
    blank:500
    IKE_LOG
    76
    2024-06-28 17:19:59
    info
    IKE
    10.187.154.135:500
    blank:500
    IKE_LOG
    77
    2024-06-28 17:19:59
    info
    IKE
    10.187.154.135:500
    blank:500
    IKE_LOG
    78
    2024-06-28 17:19:59
    info
    IKE
    The cookie pair is : 0x4cbdfa8a11ca935b / 0x0000000000000000 [count=3]
    10.187.154.135:500
    blank:500
    IKE_LOG
    79
    2024-06-28 17:19:41
    info
    IKE
    10.187.154.135:500
    blank:4500
    IKE_LOG
    80
    2024-06-28 17:19:41
    info
    IKE
    The cookie pair is : 0x6ea742077a3a1deb / 0xd7af22105c5b5bbd [count=2]
    10.187.154.135:500
    blank:4500
    IKE_LOG
    93
    2024-06-28 17:19:26
    info
    IKE
    10.187.154.135:500
    blank:500
    IKE_LOG
    94
    2024-06-28 17:19:26
    info
    IKE
    10.187.154.135:500
    blank:500
    IKE_LOG
    97
    2024-06-28 17:19:25
    info
    IKE
    10.187.154.135:500
    blank:500
    IKE_LOG
    98
    2024-06-28 17:19:25
    info
    IKE
    10.187.154.135:500
    blank:500
    IKE_LOG
    99
    2024-06-28 17:19:25
    info
    IKE
    10.187.154.135:500
    blank:500
    IKE_LOG
    100
    2024-06-28 17:19:25
    info
    IKE
    The cookie pair is : 0x6ea742077a3a1deb / 0x0000000000000000 [count=3]
    10.187.154.135:500
    blank:500
    IKE_LOG
    104
    2024-06-28 17:19:10
    info
    IKE
    10.187.154.135:500
    blank:4500
    IKE_LOG
    105
    2024-06-28 17:19:10
    info
    IKE
    The cookie pair is : 0x951287bb6803c07d / 0xb5a9e3d0de57aff6 [count=2]
    10.187.154.135:500
    blank:4500
    IKE_LOG
    117
    2024-06-28 17:18:55
    info
    IKE
    10.187.154.135:500
    blank:500
    IKE_LOG
    118
    2024-06-28 17:18:55
    info
    IKE
    10.187.154.135:500
    blank:500
    IKE_LOG
    121
    2024-06-28 17:18:55
    info
    IKE
    10.187.154.135:500
    blank:500
    IKE_LOG
    122
    2024-06-28 17:18:55
    info
    IKE
    10.187.154.135:500
    blank:500
    IKE_LOG
    123
    2024-06-28 17:18:55
    info
    IKE
    10.187.154.135:500
    blank:500
    IKE_LOG
    124
    2024-06-28 17:18:55
    info
    IKE
    The cookie pair is : 0x951287bb6803c07d / 0x0000000000000000 [count=3]
    10.187.154.135:500
    blank:500
    IKE_LOG
    126
    2024-06-28 17:18:35
    info
    IKE
    10.187.154.135:500
    blank:4500
    IKE_LOG
    127
    2024-06-28 17:18:35
    info
    IKE
    The cookie pair is : 0x6aa249cddb51cb9d / 0x0170db1383dda361 [count=2]
    10.187.154.135:500
    blank:4500
    IKE_LOG
    149
    2024-06-28 17:18:21
    info
    IKE
    10.187.154.135:500
    blank:500
    IKE_LOG
    150
    2024-06-28 17:18:21
    info
    IKE
    10.187.154.135:500
    blank:500
    IKE_LOG
    153
    2024-06-28 17:18:21
    info
    IKE
    10.187.154.135:500
    blank:500
    IKE_LOG
    154
    2024-06-28 17:18:21
    info
    IKE
    10.187.154.135:500
    blank:500
    IKE_LOG
    155
    2024-06-28 17:18:21
    info
    IKE
    10.187.154.135:500
    blank:500
    IKE_LOG
    156
    2024-06-28 17:18:21
    info
    IKE
    The cookie pair is : 0x6aa249cddb51cb9d / 0x0000000000000000 [count=3]
    10.187.154.135:500
    blank:500
    IKE_LOG
    160
    2024-06-28 17:18:08
    info
    IKE
    10.187.154.135:500
    blank:4500
    IKE_LOG
    161
    2024-06-28 17:18:08
    info
    IKE
    The cookie pair is : 0xfcbffb47f7681327 / 0x6195c47eee0d1d9b [count=2]
    10.187.154.135:500
    blank:4500
    IKE_LOG
    edited June 2024
    edited June 2024
    and after leaving it in a loop of trying to connect it did
    from when it stopping working
    Arrival Time: Jun 28, 2024 15:59:31.745253000 GMT Summer Time
    to working
    Arrival Time: Jun 28, 2024 22:47:09.830605000 GMT Summer Time
    edited September 2024
    VPN dropped out again at the same my internet dropped and the VPN is trying to reconnect but is failing going to leave it and see if it reconnects at some point.
    2024-09-04 10:42:20
    info
    IKE
    Phase 1 IKE SA process done
    10.71.71.221:4500
    92.239.xxx.xxx:4500
    IKE_LOG
    2
    2024-09-04 10:42:20
    info
    IKE
    Recv:[ID][HASH]
    92.239.xxx.xxx:4500
    10.71.71.221:4500
    IKE_LOG
    3
    2024-09-04 10:42:20
    info
    IKE
    The cookie pair is : 0x21501875e72460a2 / 0x21dfe45a2618b9dd
    92.239.xxx.xxx:4500
    10.71.71.221:4500
    IKE_LOG
    4
    2024-09-04 10:42:20
    info
    IKE
    Send:[ID][HASH]
    10.71.71.221:4500
    92.239.xxx.xxx:4500
    IKE_LOG
    5
    2024-09-04 10:42:20
    info
    IKE
    The cookie pair is : 0x21dfe45a2618b9dd / 0x21501875e72460a2 [count=2]
    10.71.71.221:4500
    92.239.xxx.xxx:4500
    IKE_LOG
    6
    2024-09-04 10:42:20
    info
    IKE
    Recv:[KE][NONCE][PRV][PRV]
    92.239.xxx.xxx:500
    10.71.71.221:500
    IKE_LOG
    7
    2024-09-04 10:42:19
    info
    IKE
    10.71.71.221:500
    92.239.xxx.xxx:500
    IKE_LOG
    8
    2024-09-04 10:42:19
    info
    IKE
    10.71.71.221:500
    92.239.xxx.xxx:500
    IKE_LOG
    9
    2024-09-04 10:42:19
    info
    IKE
    Recv:[SA][VID][VID][VID][VID][VID][VID][VID][VID][VID][VID]
    92.239.xxx.xxx:500
    10.71.71.221:500
    IKE_LOG
    10
    2024-09-04 10:42:19
    info
    IKE
    The cookie pair is : 0x21501875e72460a2 / 0x21dfe45a2618b9dd [count=2]
    92.239.xxx.xxx:500
    10.71.71.221:500
    IKE_LOG
    11
    2024-09-04 10:42:19
    info
    IKE
    10.71.71.221:500
    92.239.xxx.xxx:500
    IKE_LOG
    12
    2024-09-04 10:42:19
    info
    IKE
    Send Main Mode request to [92.239.xxx.xxx]
    10.71.71.221:500
    92.239.xxx.xxx:500
    IKE_LOG
    13
    2024-09-04 10:42:19
    info
    IKE
    10.71.71.221:500
    92.239.xxx.xxx:500
    IKE_LOG
    14
    2024-09-04 10:42:19
    info
    IKE
    The cookie pair is : 0x21dfe45a2618b9dd / 0x0000000000000000 [count=3]
    10.71.71.221:500
    92.239.xxx.xxx:500
    IKE_LOG
    15
    2024-09-04 10:42:07
    info
    IKE
    10.71.71.221:500
    92.239.xxx.xxx:4500
    IKE_LOG
    16
    2024-09-04 10:42:07
    info
    IKE
    The cookie pair is : 0x4e5abc8b83a87341 / 0xceebc8e6453cc697 [count=2]
    10.71.71.221:500
    92.239.xxx.xxx:4500
    IKE_LOG
    17
    2024-09-04 10:42:07
    info
    IKE
    ISAKMP SA [link_to_flex200_4G] is disconnected
    10.71.71.221:4500
    92.239.xxx.xxx:4500
    IKE_LOG
    18
    2024-09-04 10:42:07
    info
    IKE
    10.71.71.221:4500
    92.239.xxx.xxx:4500
    IKE_LOG
    19
    2024-09-04 10:42:07
    info
    IKE
    Received delete notification
    92.239.xxx.xxx:4500
    10.71.71.221:4500
    IKE_LOG
    20
    2024-09-04 10:42:07
    info
    IKE
    Recv:[HASH][DEL]
    92.239.xxx.xxx:4500
    10.71.71.221:4500
    IKE_LOG
    21
    2024-09-04 10:42:07
    info
    IKE
    The cookie pair is : 0xceebc8e6453cc697 / 0x4e5abc8b83a87341 [count=2]
    92.239.xxx.xxx:4500
    10.71.71.221:4500
    IKE_LOG
    24
    2024-09-04 10:41:50
    info
    IKE
    10.71.71.221:4500
    92.239.xxx.xxx:4500
    IKE_LOG
    25
    2024-09-04 10:41:50
    info
    IKE
    Recv:[ID][HASH]
    92.239.xxx.xxx:4500
    10.71.71.221:4500
    IKE_LOG
    26
    2024-09-04 10:41:50
    info
    IKE
    92.239.xxx.xxx:4500
    10.71.71.221:4500
    IKE_LOG
    27
    2024-09-04 10:41:50
    info
    IKE
    Send:[ID][HASH]
    10.71.71.221:4500
    92.239.xxx.xxx:4500
    IKE_LOG
    28
    2024-09-04 10:41:50
    info
    IKE
    10.71.71.221:4500
    92.239.xxx.xxx:4500
    IKE_LOG
    29
    2024-09-04 10:41:50
    info
    IKE
    92.239.xxx.xxx:500
    10.71.71.221:500
    IKE_LOG
    30
    2024-09-04 10:41:49
    info
    IKE
    10.71.71.221:500
    92.239.xxx.xxx:500
    IKE_LOG
    31
    2024-09-04 10:41:49
    info
    IKE
    10.71.71.221:500
    92.239.xxx.xxx:500
    IKE_LOG
    32
    2024-09-04 10:41:49
    info
    IKE
    92.239.xxx.xxx:500
    10.71.71.221:500
    IKE_LOG
    33
    2024-09-04 10:41:49
    info
    IKE
    92.239.xxx.xxx:500
    10.71.71.221:500
    IKE_LOG
    34
    2024-09-04 10:41:49
    info
    IKE
    10.71.71.221:500
    92.239.xxx.xxx:500
    IKE_LOG
    35
    2024-09-04 10:41:49
    info
    IKE
    10.71.71.221:500
    92.239.xxx.xxx:500
    IKE_LOG
    36
    2024-09-04 10:41:49
    info
    IKE
    10.71.71.221:500
    92.239.xxx.xxx:500
    IKE_LOG
    37
    2024-09-04 10:41:49
    info
    IKE
    The cookie pair is : 0x4e5abc8b83a87341 / 0x0000000000000000 [count=3]
    10.71.71.221:500
    92.239.xxx.xxx:500
    IKE_LOG
    could the problem be I use Site-to-site with Dynamic Peer on one end?
    So 8:50am today was when I lost VPN working and 3:53pm was when after itself trying to reconnect now is up.
    Seem like when my internet drops out between the two ends one side is not detecting the drop and on reconnecting fails as logs show Phase 1 IKE SA process done the problem could be Phase 2 holds on the last known encryption but the other end want to start over? so if I set Phase 2 SA life time low 180 then the next time this happens it will be that long to start the encryption over?
