USG40 - VPN Traffic VPN2Internet/VPN2LAN and back
IWAT
IWAT Posts: 15 image  Freshman Member
I set up a IKE VPN with my USG40. The VPN establishing works well, but i don't get any internet or LAN access. In the Logs it looks like the traffic goes through VPN2any, but nothing comes back, but i doesn't see any block in the Log.
What could cause thath error?
Br
  • Zyxel_Emily
    Hi @IWAT,
    Please send the startup-config.conf to me in private message. Thanks!
  • IWAT
    Hi Emily
    Thanks for you help, but the Startup config contains my whole network with PW.
    I would prefer to send you some print screens instead.
    Br Iwat
  • Zyxel_Emily
    Hi @IWAT,
    We will need the whold startup-config.conf to check if all setting are correctly configured. Before sending the configuration file to me, you can remove this line from the configuration file.
    "username admin encrypted-password xxxxxx user-type admin"
    PeterUK Posts: 4,448 image  Guru Member
    edited February 2024
    Your WAN1 being a 192.168.x.x is no need to hide but when clients get 192.168.x.x over the VPN is not conflict with other subnets?
    You may need to SNAT VPN traffic out the WAN by routeing rule unless the router upstream of USG40 does static route for the VPN clients that get 192.168.x.x
  • IWAT
    Hi Peter
    The DHCP from the USG is 192.168.2.20 - 192.168.2.200. The VPN gets usually a 192.168.60.xx address, therefore it shouldn't get any conflict. To test it i changed the VPN Adress to 192.168.2.25x, but the error is the same.
    Br Ivo
    Keep VPN clients on another subnet to not conflict
    Change Local policy to 0.0.0.0
    Make routing rule
    incoming VPN tunnel
    next hop WAN
    SNAT outgoing-interface
    Policy Control
    IPSec_VPN to WAN
    and IPSec_VPN to LAN1
    note that access to a PC on LAN1 may have a firewall blocking you
  • IWAT
    I have added the Routing rule, the Policy Control has already been created.
    But it is still not working.
  • IWAT
    I have no idea why, but it works now…
