Virtual Interfaces?
ESupport
ESupport Posts: 23 image  Freshman Member
i tried to create a virtual Interface (LAN1:1) on my Flex 100H but that (and the already mentioned LAG-Support) is not currently supported? Also i am missing the multiple SSL-VPN- "Server" so different users can access different networks.
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 981 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @ESupport ,
    1)To create virtual interface, We don't have GUI so far, please add ipv4 address under the current interface by CLI.
    #edit running
    #vrf main interface ethernet {IF name} ipv4 {IP/Mask}
    Sample: vrf main interface ethernet ge3 ipv4 192.168.99.254/24
    #commit
    then 'show interface', you will find GE3 have two addresses but won't display on GUI.
    2)For multiple SSLVPN server, We still ongoing , Thank your patience.
    Kevin
  • Zyxel_Kevin
    Hi @ESupport ,
    #edit running
    #commit
    Kevin
  • ESupport
    thanks, i will try that!
  • @monopoly go
    What is the reason behind creating a virtual interface and adding an IPv4 address under the present interface using the command-line interface (CLI) instead of a graphical user interface (GUI)?
