ZYXEL GS-105B v3 priority:
Hello. Question about ZYXEL GS-105B v3. What is the difference between MED and HIGH ports? Is MED slower? Which port has higher priority: HIGH or MED? Thank you.
  • Zyxel_Nami
    Zyxel_Nami Posts: 659 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate
    Hi @MrVrGr
    The MED and HIGH ports of the GS-105B v3 switch are part of the device's Port-based QoS (Quality of Service) feature. This feature allows the switch to prioritize traffic across different ports, optimizing performance for various connected devices.
    The key difference between MED and HIGH ports lies in their priority levels. HIGH ports are assigned a higher priority over MED ports. This means that in a scenario where the network is busy, and there is a lot of data being transmitted, the switch will prioritize traffic on HIGH ports over MED ports. This prioritization is particularly crucial for devices requiring consistent and reliable bandwidth, such as IP phones, to maintain high-quality voice calls without disruptions.
    Nami
  • Zyxel_Nami
    Hi @MrVrGr
    Nami
