Is it possible to use the static mac features to map to different vlans with gs1900?
Lets say I want to use a small unmanaged hub or switch plugged into a single port on the gs1900. Is it possible to use the static mac features to map static mac addresses to different vlans for each mac address? If so, what should the PVID on that port be set to? And the VLAN Port configuration - what should that look like?
Hi @willll ,
Based on your requirement to map static MAC addresses to different VLANs, a MAC-based VLAN configuration would be ideal.
However, it's important to note that the GS1900 series does not support this feature. For functionalities that align with your needs, I recommend considering other Zyxel switches such as GS1915 or GS1920 SeriesZyxel_Judy
Hi @willll ,
- 221 Nebula Ideas
- 609 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
