Fehler bei L2TP VPN ATP 500
Asgard
Asgard Posts: 5 image  Freshman Member
Zyxel Certified Network Administrator - Security First Comment Second Anniversary
edited February 2024 in Security
Hallo liebe Community,
ich habe mit einmal das Problem, dass sich kein Windows Client mehr per VPN über L2TP verbinden kann.
Er bricht ohne Fehlermeldung einfach ab.
In der Log erkenne ich leider auch nicht die Ursache.
könnt Ihr mir hierbei helfen?
Viele Grüße
Oliver Wend
  • smb_corp_user
    smb_corp_user Posts: 172 image  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    I am not an expert, but your log in the screenshot only contains info about normal packets.
    You need a debug log, bigger/longer than the normal information log.
    Anyway, I defer to the Zyxel team members for further assistance. Maybe you will be asked to activate some form of Zyxel Support access in your firewall configuration.
  • WJS
    WJS Posts: 156 image  Master Member
  • Asgard
    MacOS ist für uns als Unternehmen in Bezug auf bestehende Fachverfahren keine Option.
    Den Registry Eintrag habe ich natürlich vorher schon gesetzt.
    Leider funktioniert es nicht.
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 987 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @Asgard ,
    Greeting forum, Is it possible plan a remote session to check your issue ?
    I'm available at 09:00~17:00 Taiwan time, Please share your time by Private message.
    Thank you
  • Zyxel_Kevin
    Hi @Asgard ,
    Here is my Finding, I tried to test the VPN from my windoes client.
    1)The traffic from my computer is like:
    My IP → Gateway IP : 4500
    GatewayIP:4500 → My IP:4500 (Reply ICMP type3 code 10 which means administratively prohibited)
    But the firewall does not send the kind of packets from interface.
    2)And your laptop under the router can connecct VPN without issue, which means the L2TP process on Firewall is well.
    So , please try to reboot and check if any blocking on upper device.
    Keep contact by Mail.
    Thank you
