Configure SecuExtender IPSec client from command line?
ChipConnJohn
ChipConnJohn Posts: 45 image  Freshman Member
Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula First Comment Fifth Anniversary
Are there command line switches I can use to install SecuExtender with it's license code, then import a TLG file for configuration?
Thanks,
-John
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,352 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @ChipConnJohn
    Thank you for your inquiry. Currently, the SecuExtender doesn't support this feature. Thanks.
  • Zyxel_Jeff
    Hi @ChipConnJohn
