VPN not working any more after reboot
2»
  • StefanZ
    StefanZ Posts: 202  Master Member
    First Comment First Answer Friend Collector Second Anniversary
    Alright, so I had some time to experiment.
    The OLD certificate [the one used by all the team members] will not be accepted for connections anymore.
    I created a new one today and that works just fine on the same domainname.
    Switching back to the original certificate: it stops working.
    The certificate is still displayed as valid, but maybe the storage is somehow corrupted?
  • Zyxel_James
    Zyxel_James Posts: 788  Guru Member
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    Hello @StefanZ
    It looks like the original cert somehow corrupted after a restart, right? May I know your firmware version?
    I would like to know more information about the cert as well. could you send me the original cert(corrupted) and the working cert? thanks.
  • StefanZ
    current: V5.37(ABUI.2) / 2024-01-20 02:37:15
    before was V5.37(ABUI.1)
    One of our iMacs could no longer obtain an IP via DHCP on eth0, so I restarted the F200 (still on ABUI.1). After that, the VPNs that worked fine before failed. After that I updated the FW – which did not solve the problem.
    Will send the cert via PM
  • Zyxel_James
    @StefanZ
    I cannot produce the issue on 5.37P1, and we haven't received a similar issue recently.
    Please re-generate the certificate as a workaround, meanwhile, I will pay attention to this kind of issue.
